> For the complete documentation index, see [llms.txt](https://docs.mikopbx.com/mikopbx/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.mikopbx.com/mikopbx/english/faq/incoming-routing/basic-ivr-example.md).
# Basic IVR example
## Task Description <a href="#postanovka_zadachi" id="postanovka_zadachi"></a>
A customer calls the company, and a welcome message (greeting) is played.
While the greeting is playing, the customer can dial any internal extension number, for example, an employee's extension number.
Additionally, the customer can press:
* **1** - the call will be routed to the employee with extension number 201.
* **2** - the call will be routed to the employee with extension number 202.
If the customer doesn't press anything or enters an incorrect number, the call will be redirected to the **default number** - the employee with extension number 201.
The task can be visually represented as follows:
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FIcmPzMDnKCKoFp30U9Xh%2Fscheme.png?alt=media&amp;token=5d1679c5-6d7c-4a9d-842b-c521a2bcd82f" alt=""><figcaption><p>Scheme of the task</p></figcaption></figure>
## Solution <a href="#reshenie" id="reshenie"></a>
1. Create **employee accounts** by following the [instructions](https://docs.mikopbx.com/mikopbx/english/manual/telephony/extensions.md). Connect softphones or hardware phones to these accounts.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FsfjHaEwZVwb5duD4X6wH%2Fstaff.png?alt=media&amp;token=86fbe25c-5e6c-40c0-8d12-9bb89816de76" alt=""><figcaption><p>Extensions section</p></figcaption></figure>
2. Add the **greeting sound file** by following the [instructions](https://docs.mikopbx.com/mikopbx/english/manual/telephony/sound-files.md). This file will be played when the customer calls the company's phone number.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2F1QSeCSjPVol5iqOHLbf8%2FsoundFile.png?alt=media&amp;token=abd6dd76-c097-47cb-a216-88a8dfd0c54d" alt=""><figcaption><p>Sound Files Menu</p></figcaption></figure>
3. Create a new **IVR menu** by following the [instructions](https://docs.mikopbx.com/mikopbx/english/manual/telephony/ivr-menu.md).
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FgdUnQ44RBqpJTiymxbJw%2FivrMenu.png?alt=media&amp;token=917c0a91-75e4-45d6-ad08-27d96500a1d0" alt=""><figcaption><p>IVR menu</p></figcaption></figure>
When a call is made to the IVR menu (**IVR menu number**), the sound file "Greeting" will start playing.
**While the greeting is playing**, the customer can:
* Dial any internal extension, for example, an employee's extension. This is enabled by the **Allow dialing of any extension** option.
* Press 1 to route the call to the employee with extension number 203.
* Press 2 to route the call to the employee with extension number 201.
If the customer **does not enter anything** during the greeting, after the greeting plays, the system waits **7 seconds** for a digit input. "Total time for number entry" = "Greeting duration" + 7 seconds.
If the "Total time for number entry" expires, the call is redirected to the "Default number," which is the employee with extension number 101.
To **repeat** the greeting and allow the customer to enter a number again, set the **"Number of retries before redirecting to the default number"** to 2 or more. The greeting will be repeated, followed by another 7-second wait, allowing the customer to retry the IVR. Once the retries exceed the set value, the call is redirected to the "Default number."
If the customer **enters an incorrect number** or does not enter anything, the greeting will repeat (if the **Number of retries** is set to **more than 2**), or the call will be redirected to the "Default number" (if the **Number of retries** is set to **1**).
4. Add a **providers account** through which calls will be made, following the [instructions](https://docs.mikopbx.com/mikopbx/english/manual/routing/providers.md). Examples of provider connections can be found [here](https://docs.mikopbx.com/mikopbx/english/faq/providers.md).
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FEh4CEuyLLy5uRfaUG8FU%2Fproviders.png?alt=media&amp;token=d103c4da-1a2c-4117-8589-34e29d1ed8cf" alt=""><figcaption><p>VoIP Providers</p></figcaption></figure>
5. Set up **incoming calls** to be routed to the IVR menu via the configured provider.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2F5ekYAdozxEayBy5Vmcz1%2FnewRule.png?alt=media&amp;token=9a9ee606-e672-4125-85fc-cbba1ab4eb6b" alt=""><figcaption></figcaption></figure>
Instructions for configuring incoming call routing are available [here](https://docs.mikopbx.com/mikopbx/english/manual/routing/incoming-routing.md).
GET https://docs.mikopbx.com/mikopbx/english/faq/incoming-routing/basic-ivr-example.md?ask=<question>&goal=<user_goal>
