Callback: call the client back and route into an IVR
Introduction
The "callback" scenario is useful when an incoming call is expensive for the subscriber (international or long-distance calls, roaming) or when the company, rather than the client, should pay for the connection. As soon as the client gets through, MikoPBX drops the incoming call and calls the subscriber back itself, and after they answer it routes them into an IVR (voice menu) — from there the call proceeds through the usual internal routing.
It is implemented with two parts: a custom dialplan context in extensions.conf (a wrapper with a pause before dialing) and a PHP-AGI dialplan application that schedules the callback.
1. Add a custom context to extensions.conf
Go to the "System file customization" section, open the extensions.conf file for editing and append the wrapper context:
[callback-originate]
exten => _[+0-9].,1,Wait(4)
same => n,Goto(outgoing,${EXTEN},1)The context waits 4 seconds (so the incoming leg can terminate cleanly) and then sends the call into the outgoing context — that is, it dials the subscriber's number through your outbound routes.
2. Create a dialplan application
Add a new dialplan application (see Dialplan Applications), code type — "PHP-AGI script", and paste the code:
<?php
require_once 'Globals.php';
use MikoPBX\Core\System\Util;
use MikoPBX\Core\System\SystemMessages;
const CALLBACK_WHITELIST = []; // empty = for everyone
const CALLBACK_IVR_EXTEN = '2003'; // IVR number in MikoPBX
const CALLBACK_IVR_CONTEXT = 'internal';
const CALLBACK_ORIG_CONTEXT = 'callback-originate'; // wrapper context with Wait
const CALLBACK_TIMEOUT = 60000; // ms: Wait(4) + dialing
$agi = new AGI();
$raw = (string)$agi->get_variable('CALLERID(num)', true);
$caller = preg_replace('/\D/', '', $raw);
if ($caller === '') {
SystemMessages::sysLogMsg('Callback', "Empty CID ($raw)", LOG_WARNING);
return;
if (CALLBACK_WHITELIST !== [] && !in_array($caller, CALLBACK_WHITELIST, true)) {
return; // not our CID — the call will follow the usual route
// 1. Schedule the callback (the AMI action lives in the core, independent of AGI).
try {
$am = Util::getAstManager('off');
$am->Originate(
'Local/' . $caller . '@' . CALLBACK_ORIG_CONTEXT . '/n',
CALLBACK_IVR_EXTEN,
CALLBACK_IVR_CONTEXT,
1,
null, null,
CALLBACK_TIMEOUT,
$caller,
'__ISCALLBACK=1',
null,
true
SystemMessages::sysLogMsg('Callback', "Scheduled callback $caller -> IVR " . CALLBACK_IVR_EXTEN, LOG_NOTICE);
} catch (\Throwable $e) {
SystemMessages::sysLogMsg('Callback', 'Originate failed: ' . $e->getMessage(), LOG_ERR);
return; // do not drop the incoming call if originate did not go out
// 2. Terminate the incoming call the regular MikoPBX way (it sets M_DIALSTATUS and Hangup itself).
$agi->exec_goto('internal', 'hangup', '1');3. Configure the constants
CALLBACK_WHITELIST
Whitelist of incoming CIDs allowed to use callback. An empty array — call everyone who gets through back
CALLBACK_IVR_EXTEN
The IVR number (or other destination) the subscriber reaches after answering the callback
The destination context. For internal numbers and IVRs — internal
The name of the custom wrapper context from step 1
CALLBACK_TIMEOUT
Timeout (ms) to reach the subscriber, with a margin for Wait(4)
4. Route an incoming call to the application
In the "Incoming routes" section, set the created dialplan application as the destination (for the needed provider or DID). After that every such incoming call will be dropped and called back automatically.
Important points
The callback goes out through your outbound routes — the company pays for it. Restrict access with
CALLBACK_WHITELIST, otherwise the callback can be abused for free calls at your expense.The subscriber's number is taken from
CALLERID(num)and stripped of non-digit characters. It must be in a format accepted by your outbound routes and number templates; normalize it in the[callback-originate]context if needed.The IVR with the number
CALLBACK_IVR_EXTEN(in the example2003) must exist in MikoPBX (see Basic IVR example).Loop protection: the callback is tagged with the
__ISCALLBACK=1variable — use it in the custom dialplan if you need to prevent re-entering the script on the callback leg.All events are logged via
SystemMessages::sysLogMsg('Callback', ...)— search by theCallbacktag in the system log.The script is not a complete product, but is open for customization.
