Snom D120
Connecting and configuring the Snom D120 phone
Snom D120 is an entry-level desk phone by Snom. This guide explains how to connect and configure the Snom D120 with MikoPBX.
Verify that G.711 A-law is enabled under System → General Settings → Audio/Video Codecs in MikoPBX.
MikoPBX Extensions Settings
  1. Open the MikoPBX web interface and go to Telephony → Extensions:
"Extensions" section
  1. Next to the employee account you wish to connect, copy the SIP password:
Copying password for SIP
Configuring the Snom D120
Connect the D120 to your local network using the LAN port.
Scheme of Snom D120
If DHCP is enabled in your network, the phone will automatically receive an IP address. The IP address will be shown on the phone’s screen at startup.
  1. Enter the phone’s IP address into your browser as http://phone_ip_address and log into its web interface.
  2. To configure the SIP account, go to Setup → Identity 1:
"Identity 1" section
  • Identity active – set to “on”
  • Displayname – any name (preferably in Latin characters)
  • Account – the extension number of the MikoPBX employee
  • Password – the SIP password you copied previously
  • Registrar – your MikoPBX address
Click Apply, then Re-Register.
To verify, go to Status → System Information. If registration is successful, the phone will show something like:
Succesfull connection
In the MikoPBX web interface the status indicator will turn green:
Status Indicator in MikoPBX interface
Additional Settings
  1. We recommend enabling PnP Config to use the Automatic Phone Setup module features.
Configuring "PnP Config"
  1. In some cases, if DHCP is used, option 132 might be set for auto-provisioning terminals. You may need to disable this option for proper phone operation:
Option 132
