> For the complete documentation index, see [llms.txt](https://docs.mikopbx.com/mikopbx/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.mikopbx.com/mikopbx/english/faq/ip-telefones/yealink-t19.md). Agents can also search and read this documentation through its [MCP server](https://docs.mikopbx.com/mikopbx/~gitbook/mcp).
# Yealink T19
Connecting and configuring the Yealink T19 phone
The **Yealink SIP-T19** is a budget model geared toward small and medium businesses. This guide demonstrates how to connect and configure the phone with MikoPBX.
Make sure that **G.711 A-law** is enabled in **System** → **General Settings** → **Audio/Video Codecs** in MikoPBX.
## Account Settings in the “Extensions” Section
1. In the MikoPBX web interface, go to **Telephony** → **Extensions**:
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FMYas8xRoDVAaHHtirvgA%2FextensionsSectionMikoPBX.png?alt=media&amp;token=3a234730-ce5d-460b-b1b1-a4d1f25b787f" alt=""><figcaption><p>"Extensions" section MikoPBX</p></figcaption></figure>
2. For the employee account you want to connect, copy the SIP password:
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FgHGinQYeB9crv9dM9ps5%2FcopyPasswordForSIP.jpg?alt=media&amp;token=3703feff-4209-4231-a5ff-86d808494e1d" alt=""><figcaption><p>Copying password for SIP</p></figcaption></figure>
## Configuring the Yealink T19
Connect the phone to the Ethernet network using the port labeled **Internet.**
If your network has a DHCP server, the phone will automatically obtain an IP address.
Press the **OK** button on the phone to display its IP address on the screen. Then, in your web browser, enter <mark style="color:blue;">**<http://phone\\_ip\\_address>**</mark> to access the phone’s web interface.
**Default credentials**:
* **Username**: admin
* **Password**: admin
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2F08fRrHPl7cVJHT0XhGPe%2Fimage.png?alt=media&amp;token=6847dc4c-c8b4-468c-8181-e9f89477d611" alt=""><figcaption><p>Authorization window</p></figcaption></figure>
Now configure the phone’s SIP account parameters:
* **Register Name**, **User Name** – the employee’s extension number
* **Password** – the SIP password you copied earlier
* **Server Host** – the IP address of your MikoPBX server
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FmFKLkBaYE1oselqO7yca%2Fimage.png?alt=media&amp;token=82a3055a-adb6-485b-95ff-20452a23c03e" alt=""><figcaption><p>SIP account parameters</p></figcaption></figure>
In **Features** → **Intercom** → **Intercom Barge**, set the relevant parameter:
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FrDmfbavgIj0VpIE0P45g%2Fimage.png?alt=media&amp;token=4d807743-4916-448d-b04c-e98338c135e1" alt=""><figcaption><p>Intercom Barge parameter</p></figcaption></figure>
After successfully registering the phone, a green status indicator will appear next to the employee in MikoPBX:
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FVU3CcAllbozqIWCdnABw%2FsuccessfulRegistraion.jpg?alt=media&amp;token=90650c60-fc4f-4292-8fb4-b8251a3928ff" alt=""><figcaption><p>Successfull registration</p></figcaption></figure>
GET https://docs.mikopbx.com/mikopbx/english/faq/ip-telefones/yealink-t19.md?ask=<question>&goal=<user_goal>
