> For the complete documentation index, see [llms.txt](https://docs.mikopbx.com/mikopbx/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.mikopbx.com/mikopbx/english/faq/outbound-routing/outgoing-with-internal-number-dialing.md).
# Outgoing with internal number dialing
Let's say there is a certain number **+371 (2) 637‑23‑33**, by calling to which and dialing an extension you can get to a specific employee. This can be extremely convenient, especially if the extension number is longer than 3 characters. Next, we describe an example of the implementation of the task.
1. To solve the problem, additional contexts should be described through the [Customization of System Files](https://docs.mikopbx.com/mikopbx/english/manual/system/custom-files.md) menu.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2Fn06cIfMIqk6wJhcxD3gW%2FSystemFileCustomization.png?alt=media&amp;token=4edfbfbf-6903-46c5-b1b5-d2a62131f59e" alt=""><figcaption><p>System file customization</p></figcaption></figure>
2. We will edit the **extensions.conf** file.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FNuELWVzuFh5rThr08jvu%2FEditExtensions.conf.png?alt=media&amp;token=567dc075-00ed-45a7-bc10-915ccc1dc97f" alt=""><figcaption><p>Extensions.conf</p></figcaption></figure>
3. Add the following text to the end of the file:
[z-outgoing]
exten => _X!,1,Ringing()
  same => n,Gosub(${ISTRANSFER}dial,${EXTEN},1)
  same => n,Dial(PJSIP/${EXTEN}@${ZPROVIDERID},600,${DOPTIONS}TKU(z-dial-answer)b(dial_create_chan,s,1))
  same => n,ExecIf($["${ISTRANSFER}x" != "x"]?Gosub(${ISTRANSFER}dial_hangup,${EXTEN},1))
  same => n,Set(pt1c_UNIQUEID=${EMPTY_VALUE})
  same => n,ExecIf($["${BLINDTRANSFER}x" != "x"]?AGI(check_redirect.php,${BLINDTRANSFER}))
  same => n,Hangup()
[z-dial-answer]
exten => s,1,NoOp(Answered send DTMF...)
  same => n,Gosub(dial_answer,${EXTEN},1)
  same => n,SendDTMF(${ZDTMF})
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2F0108yDq0jzytZ7ZXcEeF%2FCodeForExtensions.png?alt=media&amp;token=9c5d69c2-8705-4c3e-98d7-226a9243841f" alt=""><figcaption><p>Code for extensions,conf</p></figcaption></figure>
4. Next, it is necessary to describe the [Applications of dialplans](https://docs.mikopbx.com/mikopbx/english/manual/modules/dialplan-applications.md)
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FS6mZS39XCPs3O2iIsUi2%2FNewDialplan.png?alt=media&amp;token=0b3add55-158e-4821-bb01-d894d59cf0e7" alt=""><figcaption><p>New dialplan</p></figcaption></figure>
5. Select "**Type of code**" - "**Asterisk Dialplan**"
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FgolD7wwUbLynf7PzFgCO%2FtypeOfCodeAsterisk.png?alt=media&amp;token=cb277e51-553f-4058-a68c-400f15308ebc" alt=""><figcaption><p>Type of code for dialplan</p></figcaption></figure>
6. Let's say you need to "dial" the number 3542331, set this value to "**Number to call the application"**
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FVINOSdCaVrZ2Bgb2jvnJ%2FnumberForDialplan.png?alt=media&amp;token=bc5c8fc6-ce2e-416d-92d1-bd9382197280" alt=""><figcaption><p>Number to call the application</p></figcaption></figure>
7. Go to the "**Programme Code**" tab and insert the template:
1,Set(_ZDTMF=${EXTEN})
n,Set(_ZDST=37126372333)
n,Set(_ZPROVIDERID=SIP-1601534775)
n,Goto(z-outgoing,${ZDST},1)
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2FtJFXDNv1vxBwDrHZ3ZqY%2FcodeForDialplan.png?alt=media&amp;token=03448fdf-c2a5-4ece-a06b-3f13cf6011e8" alt=""><figcaption><p>Code for dialplan</p></figcaption></figure>
* If you specify the **9XXXX** template in the "**Application call number**" field, it will be possible to "dial" any five-digit numbers starting with the digit "**9**"
* In the application, assign the variable "ZDST" the number to which the call should be made In the "**ZDTMF**" variable, specify the number for the additional set
* In the "**ZPROVIDERID**" variable, specify the ID of the provider through which the outgoing call should be made. ID can be peeped in the browser address bar when editing the provider
GET https://docs.mikopbx.com/mikopbx/english/faq/outbound-routing/outgoing-with-internal-number-dialing.md?ask=<question>&goal=<user_goal>
