MikoTalk Softphone
The module provides the API required to connect the MikoTalk softphone to MikoPBX: push notifications, call history, contacts and supervisor tools.
The MikoTalk Push Softphone API module turns an employee's iPhone into a full-featured PBX extension: calls over Wi-Fi and mobile data, incoming calls delivered via push notifications — just like a regular call, even when the app is closed.
Setting up the softphone is as simple as scanning a QR code or opening an auto-configuration link.
Features
Feature
Description
Push calls
Incoming call alerts are delivered even when the app is closed or the device is asleep
Call history
MikoTalk users see their full call history, subject to access permissions (instructions on configuring permissions). Call recordings can be played back right from the history
Contacts
A caller's name can be resolved from carrier data (if the carrier provides it) or from 1C data — connect the "Phone Panel 4.0" module for the latter
Employee statuses
Who is available and who is on a call. Call queues are visible to everyone
Transfer and pickup
Blind and attended transfer, picking up a colleague's incoming call
Supervisor tools
Listen, whisper, barge-in on a call, group monitoring
Missed calls
Unanswered calls are marked with a dedicated counter in the app
Installation
Connecting the softphone takes five steps: prepare the PBX, issue an SSL certificate, install the module, configure the firewall and connect the employee's iPhone.
Step 1. Install MikoPBX
Install MikoPBX 2026.1.223 or later — on a standalone computer, in a virtual machine or in the cloud. See Quick start for the procedure. If the PBX is already running, check its version and update if necessary.
For employees to call over mobile data, the PBX must be reachable from the internet via a public IP address / domain name.
Step 2. Obtain an SSL certificate
The app connects to the PBX over a secure connection only (HTTPS/WSS), so a trusted certificate is required — a self-signed one will not work.
  1. Install the "Let's Encrypt SSL certificate generator" module from the marketplace.
  2. In the module settings, enter the PBX's public IP address — a domain name is not required, the certificate can be issued for an IP address.
  3. Select the HTTP-01 verification method: during verification the PBX must be reachable from the internet on port 80, and "Redirect to HTTPS" must be disabled in "System" → "General Settings" → "HTTP/HTTPS".
  4. Enable "Renew certificate automatically" and click "Get/Renew SSL Certificate".
Step 3. Install the MikoTalk module
  1. In "Modules" → "Modules Marketplace" (more about the marketplace), install the MikoTalk Push Softphone API module (formerly "WebRTC Softphone Backend").
  2. Enable the module on the "Installed Modules" tab. A trial license is activated automatically on first installation — see Licensing.
  3. Open the module settings: "Modules" → "MikoTalk Push Softphone API".
  4. Wait for the status panel indicators to turn green — this usually takes up to a minute after enabling the module:
    • nginx — the app API is published;
    • push-server — push notification delivery is working;
    • STUN — the built-in coturn is running and the PBX's public address is determined;
    • Built-in status service — employee statuses and active calls;
    • SSL certificate — the certificate is trusted and issued for the address in the external server settings.
If the indicators are still not green after a couple of minutes, reload the page manually: the state may have changed while the panel has not re-read the statuses yet. If an indicator is still red or yellow after reloading, hover over it to see the reason. The most common causes are a missing or undetected public PBX address or a self-signed certificate: check the Host and Connection fields in the external server settings.
Step 4. Firewall configuration
In the PBX's own firewall settings ("System" → "Network & Firewall" → "Firewall"), enable the Softphone RTP service for the "Internet" profile — or at least for "Trusted networks" if employees only place calls from the office network. Otherwise, audio traffic is blocked by the built-in firewall.
The Softphone RTP service in the PBX firewall settings
Step 5. Connect the iPhone softphone
  1. Install the MikoTalk app from the App Store on the employee's iPhone.
  2. In the module settings, "Device setup" tab, create an auto-configuration link for the employee's extension.
  3. Scan the QR code with the iPhone camera or open the email with the link on the iPhone, then confirm sign-in in the app.
  4. Allow notifications — without them, incoming calls will not be delivered.
After connecting, place a test call to the employee's extension with the app closed: it should arrive as a regular incoming call.
Licensing
  • MikoPBX 2026.1.223 or later.
  • Licenses are issued per employee: all devices of the same employee consume a single license.
The module is installed from the marketplace. A trial license is activated automatically on first installation, so you can try the softphone before purchasing. See Registration in the modules marketplace for details on registering and renewing licenses.
Internet access to the PBX
For calls over mobile data, the PBX must be reachable from the internet: a public static IP address or port forwarding from an external IP/domain to the PBX (1:1 NAT). The following ports must be open and forwarded:
Port
Protocol
Purpose
External API port (default 8988)
TCP
App connectivity: authentication, auto-configuration link, history, statuses. The port is configured in the module settings — see External server
3478 (STUN/TURN, built-in coturn)
UDP and TCP
NAT traversal: helps the app discover its public address and build a media route to the PBX
PBX RTP port range (default 10000–12000)
UDP
Call audio traffic. The range is configured in the MikoPBX network settings
Additionally, the Softphone RTP service must be enabled in the PBX's built-in firewall — see Step 4. Firewall configuration.
For secure connections (HTTPS/WSS), use the Let's Encrypt module — it issues a trusted SSL certificate. A certificate can also be obtained for an IP address; a domain name is not required.
Connecting clients
Auto-configuration link
The app is connected via an auto-configuration link. Open the module settings, "Device setup" tab:
  1. Select the employee's extension number.
  2. Set the link lifetime: 10 minutes, 1 hour, 5 hours or 1 day.
  3. Optionally enable "One-time link" — the link stops working after the first use.
  4. Click "Create" — the module shows a QR code and the link itself.
The link can be shared by any convenient means; the QR code can be scanned with the iPhone camera. The app downloads the settings and asks to confirm sign-in.
The "Device setup" tab
The same tab contains the employee table: search by name or number, emailing a QR code to one employee or to selected ones ("Send to selected", up to 100 at a time). The email goes to the address specified in the employee's card.
To email connection parameters, first configure the PBX mail server: "System" → "Mail and Notifications". See the Mail and Notifications section for instructions.
Employee sessions
The module settings show each employee's active sessions and last activity time. The "Terminate all employee sessions" button forcibly signs out all of their devices and releases the license — useful, for example, when a phone is lost.
Module settings
The "Settings" tab
External server
The parameters the app uses to reach the PBX from the internet:
Field
Purpose
Host
Domain name or public IP address of the PBX. Determined automatically by default
Port
External web interface port, if the PBX is not published on the standard port
Connection
Plain or secure (HTTPS). Values are used for QR code generation immediately, even before saving
URI
The API address with a secret URL prefix. The refresh button generates a new prefix — all previously issued auto-configuration links stop working
Data sources
Call history and the user list always come from this PBX. The only external source is contacts:
Source
Options
Contacts
The "Phone Panel 4.0 for 1C" module or this PBX
The contacts source is available only if "Phone Panel 4.0" is installed and enabled. An availability indicator is shown next to it; if the module is unavailable, contact data is taken from this PBX.
WebRTC networks (ICE candidates)
This section determines the network route the call audio takes. When a call is set up, the PBX sends the app a list of its addresses (ICE candidates) — one per network interface — and the client picks a reachable one. If the list contains an unreachable address (for example, a VPN tunnel address), the client may end up choosing it: the call "connects" but there is no audio.
The table shows the PBX interfaces: name, network and type — LAN (local network), Public (external address) or VPN. A checked box allows offering the network to clients; an unchecked one hides it from the list.
Keep VPN tunnels disabled by default: their addresses are unreachable for employees on the internet and interfere with choosing the correct route. If audio disappeared after enabling the VPN module, the first thing to do is uncheck the VPN interface here.
Status panel
At the top of the settings page are component indicators: nginx, push-server (push notification delivery), STUN (local coturn and the external STUN from the PBX settings), the built-in status service, and the SSL certificate. If calls fail or pushes don't arrive, start troubleshooting from this panel: it shows which component is unavailable and why.
Access rights and supervisors
The "Access rights" tab
Basic rights
Without configured groups, each employee sees only their own call history and status. Other employees are not shown in the list; call queues are visible to everyone.
Access groups
An access group combines employees and defines their rights within the group:
Right
Description
View statuses of group members
Members see each other in the list along with current statuses
View the group's call history
Calls involving at least one member of the group are available
Pick up calls within the group
One can answer an incoming call ringing for a colleague
View the group's active conversations
Active calls of group members and the call parties are visible
Editing an access group
The selected rights are automatically granted to all group members.
Supervisors
A supervisor is an employee with extended rights over their own and controlled groups (the list is defined during setup). Besides monitoring, the supervisor can act on calls:
The "Supervisor" tab — extended rights over controlled groups
Right
Description
Call pickup
Answer an incoming call for a group employee
Listen to a conversation
Silently monitor a call without the parties knowing
Whisper to an employee
Talk to the employee during a call; their conversation partner cannot hear the supervisor
Join a conversation
Join the call; both parties hear the supervisor
Play call recordings
Access recordings of group employees
View active call parties
Who is talking to whom across the groups
Supervisor rights are configured on the "Access rights" tab: assign a supervisor, select the controlled groups and the required permissions.
