Let's Encrypt
Instructions for issuing trusted SSL certificates
Let's Encrypt is a free, automated Certificate Authority (CA) that issues trusted SSL/TLS certificates to secure websites and services over HTTPS.
When is this certificate useful in MikoPBX?
If your PBX is accessible from the internet and you want to secure the admin web interface.
For secure WebRTC client connections (browser-based calls require HTTPS).
To eliminate browser warnings about "insecure connections".
If you use mobile apps or SIP clients that require a valid certificate.
System requirements:
A domain must be assigned to the PBX, for example sip.test.com
The PBX web interface must be accessible from the internet via
HTTPon port80(for HTTP-01 verification method)In the general settings (section "HTTP/HTTPS"), disable the "
Redirect to HTTPS" option — the Let's Encrypt server accesses your PBX viahttpduring verification. (for HTTP-01 verification method)
Module Installation
Go to "Modules" -> "Module Marketplace".
Navigate to the "Marketplace" tab. Install the module "Generator Let's Encrypt SSL certificate".
Obtaining a Certificate
Return to "Installed Modules". Enable the installed module and open its settings.
Fill in the general information:
Domain name without http and https, only the name — enter the domain name of your PBX.
Verification method — choose one of two options: "HTTP-01 (Port 80)" or "DNS-01".
Enable the "Renew certificate automatically" option.
If you selected the DNS-01 verification method, fill in the additional fields:
DNS Provider — select your provider from the list (e.g., Cloudflare, Route53, Namecheap, etc.)
API Token — paste the API access token obtained from your DNS provider's control panel. The token must have permissions to create and delete TXT records in the domain zone.
Account ID — your account identifier at the DNS provider. Usually found in profile settings or the "Overview" section of the control panel.
Zone ID (Optional) — the DNS zone identifier for your domain. Typically displayed on the domain's main page in the provider's control panel.
Click "Get/Renew SSL Certificate".
The result of the certificate request will appear in a black console window.
In the "System" -> "General Settings" section, under the "HTTP/HTTPS" tab, you can find information about the issued certificate.
