Module auto dialer
Auto Dialer Module
This module provides a REST API for creating campaigns to automatically dial external numbers:
  • When an employee is available, the module dials a phone number from the campaign pool.
  • When the client answers, the call is connected to the internal queue or the employee’s extension.
  • If the internal number is busy, the call is automatically terminated.
REST API Authentication
For all requests, except local ones, authentication is required.
By default, you can use the web interface's administrative password for authentication.
To restrict access to specific PBX settings, the "System Access Management" module can be used.
Example request:
curl 'http://172.16.156.223/admin-cabinet/session/start' \
-X 'POST' --cookie-jar auth-cookies.txt \
-H 'Content-Type: application/x-www-form-urlencoded; charset=UTF-8' \
-H 'X-Requested-With: XMLHttpRequest' \
--data 'login=admin&password=adminpassword'
Where:
  • login – admin, the web interface username.
  • password – adminpassword, the web interface password.
  • 172.16.156.223 – the MikoPBX server address.
Response example:
Example of executing requests:
Polls
Allows you to organize automatic client surveys. Using the API, you can define a set of questions, their connections, and answer options.
It is possible to use text-to-speech generation or pre-recorded mp3/wav files.
Adding a Poll
Example cURL request:
Fetching Poll List
Response example:
Creating a Task
Response example:
Media Files
Uploading Media Files
Response example:
