> For the complete documentation index, see [llms.txt](https://docs.mikopbx.com/mikopbx/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.mikopbx.com/mikopbx/english/modules/miko/module-callback-queues.md).
# Callback module
This module is designed to handle missed calls automatically. Whenever a missed call is detected, a callback task is created. As soon as an employee becomes available, they receive a call; once they answer, an attempt is made to connect with the client.
Let's walk through the module's functionality with a few examples:
## Missed Call
A client attempted to contact the company but was unable to reach anyone. This might happen for various reasons, such as:
* The call was disconnected.
* The client hung up before anyone answered.
In response, the module generates a callback task. Once an employee becomes available, they receive the task call.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2Fcxn4zxk6kSGMFfyN9cpa%2FoverviewEN.jpg?alt=media&amp;token=948f4813-6198-4f4b-a96c-b9df5c8f7fa6" alt=""><figcaption><p>Module overview</p></figcaption></figure>
An alert sound file can be played for the employee. You can specify this file in the module settings under **Alert "A connection with the client will be made."** After the notification, the system will initiate the client call.
Employees handling missed calls should be added to a shared **Call Queue**. Set the queue number or employee number for handling missed calls in the module settings.
Not every answered call can be considered successful. The module allows you to define a criterion, **The duration of the answered call, which we consider successful.**
If the call is unsuccessful, you can set retry parameters:
* **Delay** – interval between retry attempts
* **Number of call attempts**
Older calls may no longer be relevant, so there is a configurable “expiry time” for missed calls. Calls and tasks older than the set **The number of seconds to analyze missed in the history** will not be processed.
## Callback Request from Client
In cases where a client is tired of waiting and requests a callback, the module can handle it as well. Specify the sound file in **Alert "The request for a callback has been accepted"**
Once the client presses **1**, a callback task is created, and the client hears the confirmation notification. The **Press 1 to request a callback** feature is available in queues listed under **Queues for callback**.
You can also configure additional notifications in the **Advanced** settings for individual queues.
The **Ad phrase or additional notification** setting for queues only works when all employees are **busy**.
<figure><img src="https://835495363-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsZ8acWnNlSalIHQjMFu1%2Fuploads%2F3Is2ebtAq0md2PCKRzWW%2FadNotificcatorEN.jpg?alt=media&amp;token=4deb90c9-d8dc-4c2f-afae-feb11a5daaed" alt=""><figcaption><p>Additional settings in the queue section</p></figcaption></figure>
This feature can, for instance, prompt the client to press "1" to initiate a callback request.
GET https://docs.mikopbx.com/mikopbx/english/modules/miko/module-callback-queues.md?ask=<question>&goal=<user_goal>
