Using a Huawei E173 USB Modem for Calls (chan_dongle)
Connecting a Huawei E173 3G USB modem to MikoPBX via chan_dongle
The Huawei E173 is a USB 3G modem from Huawei that is compatible with the chan_dongle module for Asterisk. By using this modem with chan_dongle, you can configure Asterisk to make voice calls and send SMS messages over the GSM network, effectively turning the modem into a full-fledged GSM gateway.
Preparing the USB Modem
First, let’s see which USB devices are connected to the PC:
lsusb
Bus 001 Device 002: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA Modem
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hubWe’re interested in the device "12d1:1001 Huawei Technologies...".
12d1 – the vendor ID.
1001 – the product ID.
For the modem to function properly, you need to switch it to "1001" (modem-only mode).
Next, search for device info using the vendor ID "12d1":
dmesg | grep 12d1
[ 2.828272] usb 1-1: New USB device found, idVendor=12d1, idProduct=1001, bcdDevice= 0.00Then check for info by the USB device number "usb 1-1":
We see the modem’s serial devices: ttyUSB0, ttyUSB1, ttyUSB2.
Checking the Modem Settings
You’ll see something like:
You can now enter AT commands to manage and configure the modem.
Example Commands
AT^CARDLOCK? – Checks SIM lock status and the remaining attempts to enter an unlock code. (The modem’s response:
CARDLOCK: A,B,0. If A=2, modem is unlocked; A=1, locked — SimLock; A=3, you either used all 10 attempts or have a customized firmware. B is the remaining number of attempts, typically 10.)AT^CARDLOCK="NCK Code" – Unlock the modem to work with all mobile operators (if you have the code).
AT^CVOICE=? – Checks the modem’s voice support state (0 means voice is enabled).
AT^CVOICE=0 – Enables voice functions on the modem.
AT^U2DIAG=0 – Switch the modem into modem-only mode.
What to Verify?
Confirm the modem supports voice functions.
The modem must be in "modem-only" mode (ID 1001).
If possible (and if you have a code), unlock the modem for use with any operator.
chan_dongle for Asterisk
In the MikoPBX web interface, go to System → Customize System Files.
Open
/etc/asterisk/modules.conf.Set the mode to "Append to the end of the file".
Add:
Open
/etc/asterisk/dongle.conffor editing.Choose "Replace Completely".
Paste the following configuration:
Re-open
/etc/asterisk/modules.conf.Again choose "Append to the end of the file".
Add contexts for SMS and USSD handling:
After configuring dongle.conf, you must restart your PBX.
Configuring DID
Each dongle requires a DID number for correct inbound call handling.
Enter the Asterisk console:
List the dongle devices:
If the
Numbercolumn is empty, run:
Restart your PBX afterwards.
Configuring an Inbound Route
In the web interface, go to Call Routing → Incoming Routing.
Create a new rule. In the DID field, specify the SIM’s phone number you set earlier:
Configuring Outbound Routes
In Call Routing → Providers, create a new SIP account with:
Name – “Dongle0” (or any name)
Host or IP – 127.0.0.1
Account Type – “Authentication by IP address, no password”
Copy the Provider ID from the browser address bar (e.g., SIP-TRUNK-C4153448).
In Call Routing → Outbound Routing, create a new rule for sending calls via the modem:
Go to System → System file customization and open
/etc/asterisk/extensions.conf. Choose “Add to end of file” and add:
